Fusion does not export to STEP
Message 1 of 10
I have tried to export to STEP files but it has not worked.
I reopened Fusion but it was the same.
What can I do?
Replies (9)
Message 2 of 10
g-andresen
did you export from File or via rightclick from browser?
günther
Message 3 of 10
TheCADWhisperer
Let’s see what you have.
Message 4 of 10
Hello Günther,
I did it from "File".
Message 5 of 10
Unfortunately, I can not do that either.
Message 6 of 10
g-andresen
Try the other option.
günther
Message 7 of 10
jeff_strater
what is the nature of the failure?  Do you get an error?  What is the error?  What is in the design you are trying to export?  Are you willing to share it here?  That is the easiest way to get help - share the design.
Jeff Strater
Engineering Director
Message 8 of 10
It is just a plate with a 6mm diameter hole.
I did all the process and clicked "Export".
But it does not show anything afterwords and the file is not saved in the folder.
I could do this yesterday but it stop doing it this morning.
We have two accounts and I tired both, but it did not work.
Message 9 of 10
jeff_strater
If it was working yesterday, that's a good sign.  I know I can export as STEP a model that simple, but just to be sure, can you post that model here so I can try it?  Are you exporting from the Export menu in Fusion (as opposed to exporting it from A360/Fusion team via the web browser)?
Jeff Strater
Message 10 of 10
ryan.bales
Autodesk Support
Autodesk Support
I've seen this a number of times and the only solution i've found is to 'Clean uninstall'. In all cases the Logs show a QT Notify error and it would explain why the dialogs aren't working. it would be really helpful if you could upload your log files for investigation.
Ryan Bales
Fusion 360 Product Support
