Fusion can't connect to the internet - tried everything
moritz_schaefleQNA7M
Message 1 of 8
Hello all,
unfortunately I have for some time now trouble with Fusion and its connection to the internet.
I uninstalled and installed it, reseted Fusion and I am quite confident, that everything should work.
This is the result of the network test:
The mcmaster page can be accessed via browser, so I am having trouble to understand what the problem is here.
No antivirus software should block Fusion. I created the log-files, maybe there is some helpful information in them.
If more information is necessary to identify the problem, I would gladly provide that.
Kind regards
Moritz
Replies (7)
Message 2 of 8
RajkumarIlanchelian
@moritz_schaefleQNA7M Thank you for the logs. We will check this. In the meantime couple of tests for me please.
1. Connect to a different network (your mobile hotspot maybe) and see if you experience the same ? 2. Restart your router and see if that makes a difference.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
@RajkumarIlanchelianThank you for your reply.
The two test you suggested unfortunately did not make a difference. The problem persists.
Kind regards
Moritz
Message 4 of 8
evanss801
I have this exact same issue and when trying to install the client downloader it says
SSL Failed to verify the server certificate.
I have been through all the help with tech support and they passed me to this forum where I have 2 created threads and no responses.
Message 5 of 8
RajkumarIlanchelian
@moritz_schaefleQNA7M @evanss801 Pardon my delay to respond. Can you please try the below if you are still experiencing the problem?
1. Close Fusion
2. Go to  C:\Users\<USER>\AppData\Local\Autodesk\Identity Services\idservices.db
Can you delete the iservices.db file and then restart Fusion?
Autodesk Fusion
Join Fusion Insider
Message 6 of 8
@RajkumarIlanchelianThank you very much for your suggestion. Unfortunately, this did not solve the problem and the issue persists.
Kind regards
Moritz
Message 7 of 8
RajkumarIlanchelian
@moritz_schaefleQNA7M Can you please run another quick test?
On the windows machine create another user and install Fusion on that user account. Does that cause the same problem?
Autodesk Fusion
Join Fusion Insider
Message 8 of 8
evanss801
This post may help you!
https://forums.autodesk.com/t5/fusion-support/ssl-certificate-error-when-trying-to-install-fusion-36...
I managed to get this fixed myself with help from our Local authority IT services by tracing any blocks that happened through the internet filtering service.
