Fusion 360 Takes a Long Time Exporting .stl Files
Message 1 of 32
For some reason my .stl exporting now takes around 5-10 minutes to complete. I can't remember exact timing for the change over, but I was working on a big project 6 months ago and I would export files and watch the loading bar complete when I would export files. Has anyone else seen this issue?
thanks,
Replies (31)
Message 2 of 32
wmhazzard
Just right click on a body and click save as STL, it saves it to your computer and is much faster.
Message 3 of 32
mechatronicus
Thank you for the info, it does work, but it's really stupid that the same goal takes different times to complete if you choose a different approach. It's exporting an stl file when you do it the regular way too, why does it take 5 minutes? Can't you just use the same method you're using for right click save as stl and use it when going file export stl!?!?!?! It's really stupid it's like this.
Message 4 of 32
manolo.dev
I can't find in the menu the option to export or save as...
Message 5 of 32
wmhazzard
Export is under the file tab at the top left of your screen or by right clicking the top level in the browser. To save as STL, right click on the body in the browser or the body itself.
Message 6 of 32
manolo.dev
Thanks just found in the browser, I could not find the save STL in the model itself.
Message 7 of 32
does it take so long to export from the actual export function because its trying to do all the work on the cloud? My internet isnt always great but my PC is a beast so itd be nice if we could force export on our local machine
Message 8 of 32
I notice is better to stop internet in the computer, so Fusion enters in offline mode and everything is faster.
Message 9 of 32
roblatour
Observer
Observer
Thanks so much for posting this, I have been dealing with really slow exports for over a year.  Finally fed up today I search and found this response.  One odd thing however - the very slow export from the file menu produces an export file (in my case - sample of one print model) well less than half the size of the much more speedy 'save as stl' output as described below.   Both however seem to render the same in Prusa slicer.
Message 10 of 32
vewoci6695
Observer
Observer
If it was just an offline program they couldn't data mine you for all you're worth (and charge paying customers by the month to make 10x as much money as they used to).
I had this same issue. 5 minutes to export a .stl when going the Export>.stl route. 3 seconds when right clicking the body and saving as stl. The only difference I could see was the 5 minute file was 300kb smaller.
Message 11 of 32
I have the same problem with exporting any file in Autodesk fusion . it takes ages to export a very very simple file to any format.
it took almost 5 minutes to export a simple cube into dwg or dfx. this is very bad.
Message 12 of 32
Yes same problem here, a cube takes 5 minutes to export in .STL, it's a shame, with my pc takes probably 2 seconds with every others CAD software.
Message 13 of 32
TheCADWhisperer
@Anonymous
Show Screencast recording.
Are you attempting to export via the data panel or directly via right click?
Message 14 of 32
TheCADWhisperer
@Anonymous
Message 15 of 32
TheCADWhisperer
@Anonymous @Anonymous
Where did you go?
Did you figure out how to export directly without going through the cloud?
Message 16 of 32
Hello The CadWhisperer. Sorry for my delayed response. Had a busy time. I am preparing a screencast and will uploaded here.
Message 17 of 32
Here is a screencast of the long wait time for exporting a simple cube.
Message 18 of 32
TheCADWhisperer
When I watch your video, I realize that you must not have understood the first reply in this thread by @wmhazzard .
Right click on the Body and select Save As STL.  It is much much faster and gives you more options on quality.
Message 19 of 32
I just tried that. I confirm that saving as STL file from right click menu on browser works fast.
So do you think there might be a problem with the export application?
Message 20 of 32
TheCADWhisperer
Apparently Autodesk does not think it is a problem - it has been that way in Fusion for as long as I can remember.
