Editing a stored drawing.
spancheau
spancheau
I stored  a sketch before applying the 2d machining thinking I could then open the drawing and edit any errors. It seems like I can add features to the sketch, but not delete the incorrect lines. I click on them just like a new sketch and the line highlights but when I click on delete they are not removed. Is there a different approach needed when bringing a stored sketch in to design?
Scott
ryan.bales
Autodesk Support
Autodesk Support
I'm really not sure what you mean.
Are you editing the sketch in question? What do you mean by stored sketch?
Ryan Bales
Fusion 360 Product Support
g-andresen
to edit a sketch it has to be activated first.
This is done in the browser or the timeline either by double-clicking or by right-clicking > Edit.
günther
spancheau
I saved the sketch in the data panel thinking I could then open it and make
edits. I had opened a 2d item from the data panel and I could not figure
out how to get it back to an editable sketch, so the next time I saved the
sketch before applying the 2D machining thinking I could then bring that
back in and make edits. When I do that I am not able to delete the lines or
arcs that I don't want, but I can add new lines.
spancheau
Thank you so much!
