fusion 360 not responding
Message 1 of 14
as i upload the file say reciprocating saw it upload well but as i double click on it every thing got stuck and "not responding" appears on the top and sometimes after double click everything go well but no modelprb1.PNGprb2.PNG is there to see on screen
Replies (13)
Message 2 of 14
ryan.bales
Autodesk Support
Autodesk Support
This looks like there are some graphical issues going on. In the bottom photo i do not see the viewcube - which we most certainly should see.
What graphics card does your computer have?
Ryan Bales
Fusion 360 Product Support
Message 3 of 14
nvidia GeForce 940MX
Message 4 of 14
ryan.bales
Autodesk Support
Autodesk Support
Are your drivers up to date?
Ryan Bales
Message 5 of 14
Yes they are totally updated
And i updated them recently only one week ago
Message 6 of 14
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
If this is graphics related we need to check everything:
What is the screen resolution?
Display scaling?
How many monitors? 4K? External?
If so does it work on the laptop screen?
Do any files work and operate fine?
Ryan Bales
Message 7 of 14
baribak
If this is a Windows 10 system can you check to see if Duet Display is on? If so, turn it off and try launching Fusion.
Kevin Baribault
Fusion 360 Quality Assurance
Message 8 of 14
how to turn it off
i am unable to find any options
Message 9 of 14
sorry
i confirmed that duet is installed on my system
so this will not fix the problem
Message 10 of 14
ryan.bales
Autodesk Support
Autodesk Support
You'll likely need to uninstall Duet Display. You may be able to end the service in services.msc but i've not seen that tested yet.
Ryan Bales
Message 11 of 14
baribak
I'm sorry but it's unclear to me if you have it or not. Here's some info from Duet on how to uninstall:
Uninstall Windows
  1. Go to Control Panel > Add or Remove Applications and select Duet Display.
  2. This will ask you to restart your PC to uninstall.
  3. After you reboot, open Control Panel > Add or Remove Applications and confirm that Duet Display as well as Kairos Display are removed from the list.
  4. On some occasions you must uninstall a remaining component of Duet because Windows separated them during the uninstall process. If so, just select the component, uninstall and restart your PC once more.
If Duet is not installed, then try resetting your monitor resolution (if not at 1920x1280), see if Fusion loads, and try going into Preferences and changing the Graphics Driver to DX9.
If Fusion won't load after resetting the monitor try deleting the files NMachineSpecificOptions.xml, NGlobalOptions.xml, and NULastDisplayedLayout.xml. They can be found starting in:
C:\Users\username\AppData\Roaming\Autodesk\Neutron Platform\Options
Then relaunch Fusion.
Kevin Baribault
Message 12 of 14
no such file exist
still unable to use fusion360
i have tried everything u suggested but nothing is working
Message 13 of 14
Message 14 of 14
baribak
Sorry to hear of the continuing challenges.
Can you try setting the "Size of Apps" to 100%?
Also, can you send us the log files?  These can be found in :
C:\Users\username\AppData\Local\Autodesk   - streamer.log
C:\Users\username\AppData\Local\Autodesk\Autodesk Fusion 360\logs AppLogFiles
C:\Users\username\AppData\Local\Autodesk\Web Services\logs
Kevin Baribault
