Fusion 2704.1.23 - Server Verification Warning, HTTP 403 after successful sign-in, unable to access cloud services
slava124678
slava124678
Community Visitor
Community Visitor
I have a problem with Autodesk Fusion 2704.1.23 on Windows 11 25H2 (Build 26200.8655).
Fusion starts normally and I can successfully sign in to my Autodesk account. The license is activated successfully.
Immediately after signing in, Fusion displays:
Server Verification Warning - Unable to validate a security certificate
If I click Trust Anyway, Fusion then shows:
Sorry, Fusion was unable to save sufficient data for offline mode and needs to go online.
Fusion cannot continue and cloud services are unavailable.
What I have already tried
  • Complete reinstall of Fusion.
  • Reinstall Autodesk Identity Manager.
  • Reset Login State using Autodesk Licensing and Sign-in Helper.
  • Created a new Fusion Team Hub.
  • Tested with two different Autodesk accounts.
  • Tested with two different Internet connections (home Wi-Fi and mobile hotspot).
  • Updated Windows to the latest version.
  • Verified and regenerated Windows root certificates.
  • Microsoft Defender is the only antivirus installed.
  • Autodesk Access reports no available updates.
Diagnostic information
Fusion logs show:
  • Successful authentication.
  • Successful license activation.
  • Requests to Fusion Team endpoints fail with HTTP 403.
  • Requests to:
fusionteam/login/v2/hubs
return 403 Forbidden, after which Fusion cannot retrieve Hub information or access cloud services.
Identity Manager appears to work correctly.
I have Fusion logs, Identity logs, and installer logs available and can upload them if needed.
Has anyone experienced this issue or knows how to resolve it?
lauri_barnhart
Welcome to the community, @slava124678.
Just checking in to see if you are still needing assistance or have you found a solution. If you still require assistance, please provide an update here with any of the logs or other information you have.
Best,
Lauri | Community Manager
