Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Error: Edit Surface Revolve, Axis get added to Profiles.
KristianLaholm
Message 1 of 8
KristianLaholm
Hi
On editing a Surface Revolve I get an error if I used a sketch line as axis.
The error comes from that the axis gets added to the profiles.
Replies (7)
Message 2 of 8
KristianLaholm
Message 3 of 8
TheCADWhisperer
Axis selected in Profile.
Ctrl or CMD unselect the axis as Profile.
Well, this is interesting.
I edit the sketch and change the axis to Construction.
Delete the Revolve and recreate and it still selects both lines as Profile even though I select only the solid line.
Message 4 of 8
jhackney1972
The best solution is not to sketch the revolve axis but to use the Z axis instead.  But since you asked the question, just change the vertical line from an object line to a construction line, then the program will ignore it.  Model attached.
John Hackney, Retired
Message 5 of 8
KristianLaholm
The workaround using a construction line is the one I'm using if there is no axis to use.
But I think the behavior (adding axis to profiles on edit) is new, I can't recall noticing this behavior earlier.
Message 6 of 8
HughesTooling
@jeff_strater  Is this a known bug?
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 8
davebYYPCU
Cancel Chain Select,
If happens with that off, then it is a new process.
Might help...
Message 8 of 8
jeff_strater
no, that is a new one on me.  Head-scratcher.  I created FUS-80829 for this one.
Jeff Strater
Engineering Director
