Bug Report: Post Process panel too big when Properties disclosed
andrewbarton
andrewbarton
If I disclose the Properties section of the Post Process panel, even if the Settings are undisclosed, the panel is too big to fit on the screen.  The lower options and the "OK"  and "Cancel" buttons are not accessible.
The attached photo shows the problem.
Is it possible to add a scroll bar?
MacBook Pro M1 running Big Sur
Accepted solutions (3)
HughesTooling
Windows has a different dialog so not sure if this will work, can you dock the dialog to the right edge of the window? For all other dialogs, when docked you get scroll bars if they are too big to display.
Mark
Mark Hughes
Owner, Hughes Tooling
andrewbarton
Thanks Mark, that helped!
I didn't realise I had to move the dialog so far to the right in order to get the green bar...
This tip also helped:
http://help.autodesk.com/view/fusion360/ENU/?caas=caas/video/youtube/watch-v-SvzxM3W7puA.html
Thanks again,
Andrew
HughesTooling
One thing to note is the green bar will appear when the mouse pointer reaches the edge of the window so if you grab the dialog near the right side of the title bar you don't need to move it as far.
Mark
Mark Hughes
andrewbarton
Very helpful!!
