Drag and drop not working anymore for uploading files
timonsku
Message 1 of 16
timonsku
As the title says. It just stopped working for me. I can only upload files by going via the select file menu but draging a file into the drag and drop area does not upload it.
Replies (15)
Message 2 of 16
jhackney1972
What environment exactly are you trying to drag and drop? A360?
John Hackney, Retired
Message 3 of 16
timonsku
The upload dialog in Fusion 360
Message 4 of 16
jhackney1972
I do not find any issues with Drag and Drop feature in the Upload dialog box.  It works as expected.
Message 5 of 16
timonsku
Great but not really helping me 🙂
Message 6 of 16
TheCADWhisperer
What file type are you attempting to drag and drop?
What license type do you have?
Message 7 of 16
timonsku
Both a free license for hobby work and a commercial license for work.
I tried uploading a step file. Uploading that file works absolutely fine
via the browse button. Just the drag and drop action is not working.
Message 8 of 16
TheCADWhisperer
Can you Attach an example file here that does not work (create a simple dummy file if your actual file is proprietary).
Message 9 of 16
timonsku
Again, the file itself makes zero difference. The action of hovering a file over the field is not detected any more for me in Fusion. The file upload works perfectly and the exact same files that I tried to upload have worked before via drag and drop. This is a UI code issue, it has nothing to do with the file.
This is not something that can be fixed by a community member or by doing something differently. Something with my system setup seems to cause this bug.
This is how it looks if I drag a file over to the field (had to make a photo, screenshots on windows dont capture cursors)
Message 10 of 16
jmendezfl
Community Visitor
Community Visitor
I know it's been a long time since this was posted, but I didn't see an accepted answer. I recently completed Kevin Kennedy's class and I had the same problem during one of the projects. It turns out that I just needed to make sure that the timeline marker was at the end of the timeline when I was trying to reorganize the components in the Browser. He explains that is due to "Fusion 360 been a parametric modeler, which means that the order in which features are created matters, as they reference existing features in the timeline.
Message 11 of 16
owen.fouraker
Community Visitor
Community Visitor
I have the same problem
Message 12 of 16
lhen12000
Community Visitor
Community Visitor
I have found that if the files which you desire to upload via drag and drop is within a .ZIP folder then you cannot upload them, but if you were to extract the contents from the .ZIP folder and upload them again then it should work.
Message 13 of 16
timonsku
No this was not a zip file, I was trying to upload a step file.
This is still a problem btw. it never resolved, I always have to choose files via the file dialog.
Message 14 of 16
Linus_Follinger
I have had the EXACT same problem for 2 years, it worked before that.
i have Re-installed, Repaired Fusion, several times, to no differeance.
as you say, the file type does not matter.
i havent tried to re-install windows yet.
it does work for my collage that have the exact same PC components.
Message 15 of 16
1494454
Community Visitor
Community Visitor
I have also recently gotten this problem after only a few days of use
it's very annoying to deal with
Message 16 of 16
timonsku
The problem only went away after I reinstalled Windows with my upgrade to Windows 11 unfortunately
