Document stuck uploading
adamsa
Message 1 of 54
adamsa
I have a document that is "still uploading" per the screenshot below. When I check the queue and look online, I don't see the document anywhere. I have also check on other computers and shows the same thing from within the app.
Issue is that it's counting against my editable documents? Any idea how to clear this?
Replies (53)
Message 21 of 54
dhuff3751
Community Visitor
Community Visitor
Worked for me.  Thank you
Message 22 of 54
christian_collins
Message 23 of 54
steve_kampen
Observer
Observer
I tried this step and I did not resolve my issue.  In my case, I suspect that the files that are being a problem are part of a system crash I had the other week working online with a at best sketchy internet connection.  Any help would be greatly appreciated.
Message 24 of 54
RajkumarIlanchelian
@steve_kampen Can you play grab a quick visual of what you are seeing or where the files are showing as stuck? the logs does not show any evidence of files left over on machine to be uploaded to the cloud. Also, do you have the personal license?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 25 of 54
steve_kampen
Observer
Observer
Yes, I have a personal license
Message 26 of 54
RajkumarIlanchelian
@steve_kampen The solution called out should absolutely work. Rather than rename can you delete the active document file? It's also important that you go into the off-line mode.
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
Autodesk Fusion
Join Fusion Insider
Message 27 of 54
steve_kampen
Observer
Observer
Thank you, that seems to cleared up the matter.
Message 28 of 54
leichito
Community Visitor
Community Visitor
excelent!
Message 29 of 54
thomspam
Community Visitor
Community Visitor
Thanks, Steve!
Message 30 of 54
charlesredgar
Community Visitor
Community Visitor
I was having the same problem and the fix worked for me as well.  Thank you.
Message 31 of 54
RajkumarIlanchelian
@charlesredgar
1. Open Windows explorer
2. Type in %APPDATA%\
3. Then navigate to - Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
Autodesk Fusion
Join Fusion Insider
Message 32 of 54
don_etc
Observer
Observer
How do you change the editable property of a document online if you have a personal, non-commercial license?
Message 33 of 54
RajkumarIlanchelian
@don_etc When you say online I assume you want to do it outside of the Fusion desktop application. If so you can login to Fusion team - https://login.autodesk360.com/login and make documents read only/editable.
Autodesk Fusion
Join Fusion Insider
Message 34 of 54
ranmck
Community Visitor
Community Visitor
I'm having this issue as well. I'm not comfortable changing file names (I'm a very occasional user), so what do I change the file name to, and how do I change it? I just get a list of possible programs to open it. I'm afraid I'm going to lose files or otherwise screw something up.
Message 35 of 54
RajkumarIlanchelian
@ranmck @Please follow this
Pleae let the customer know this:
1. Update to the latest version 2.0.20508 or newer
2. Then run this workflow from the article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Both of these will ensure that the current problem is fixed and the new version will ensure that customers do not hit the problem again.
Autodesk Fusion
Join Fusion Insider
Message 36 of 54
ranmck
Community Visitor
Community Visitor
I did this, now my designs are gone. How do I get them back?
Message 37 of 54
RajkumarIlanchelian
@ranmck All this does is makes your editable designs back to zero. Go to the project and make the design editable again.
Autodesk Fusion
Join Fusion Insider
Message 38 of 54
sinoque56
Community Visitor
Community Visitor
ok ! la solution a fonctionné ! merci
Message 39 of 54
don_etc
Observer
Observer
That doesn't seem to show an option to make read-only or editable. When I right-click in the project list, I get a menu that shows:
If I navigate to the document examine the properties I can't seem to find a read-only vs editable option.
Message 40 of 54
robife
Observer
Observer
Thank you so much, that help me.
