- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My current understanding of 360 is that in order to edit a text element in a sketch, that element has to be activated by double clicking on it. Also, that element can be double clicked only it there is a direct line of sight to the element. If a body is obstructing the direct view of that element it cannot be double-click activated. At least, I don't see any other way of doing so, but please correct me if I'm wrong.
In any case, while I was editing an existing sketch in the timeline, one which I created to add text to the design, I turned off body visibility in order to gain direct access to the text element I wanted to edit. Once I edited the text I clicked to FINISH SKETCH, and I then turned on body visibility back on to show the body again, but the body never showed up again. The sketches were there, and all the features in the timeline and browser tree were there, but not the body. I tried several different things to see if I could 'bring back' the body, but nothing.
I then tried 'View Details on Web', and tried to open the file there. I got this:
Model is empty, there is no geometry for the viewer to show.
•Please contact the author.
•Please upload the file again to see if that fixes the issue.
At that point my only option was to open the previous version I had saved, update it, and re-save it.
This has now happened to me twice; same sequence of events. Once earlier today, and once 2 days ago (with a full reboot of my system in-between). That leads me to believe that this is a glitch within the app, and not in my system, I presume.
Fortunately, I was able to perform the edits I needed to do —both times— because it was possible to target the text element, without obstruction from the body, by precisely reorienting the body to a position that allowed direct access to the text element. After that, it was just a matter of zooming in far enough to have enough surface to double-click on.
I look forward to your response. Thank you!
