Circular Pattern Extrude/cut
mcjj29909
mcjj29909
Circular pattern does not work.
Further in in the timeline you'll see I did set a tangent plane then sketch onto that plane then extrude/cut followed by circular pattern and that works.
Why doesn't it work using the origin plane?
https://a360.co/3govrQx
TheCADWhisperer
Are any of your sketches fully defined?
How many bodies do you have?
mcjj29909
After the circular pattern of the 'fastening tab' there are now 3 bodies. Please see steps below that are in the timeline of attached drawing link
1 - I created the sketch with one 'fastening tab'.
2 - Then I extruded the sketch.
3 - I added my slot sketch to the origin plane
4 - Then extruded/cut the slot
5 - I tried to circular pattern the 'fastening tab' & slot but only the tab worked.
6 - I abandoned the slot as part of the circular pattern
7 -I did a circular pattern of the tab with success
8 - I then tried to circular pattern the slot without success
9 - Finally tried by adding a tangent plane
10 - sketched the slot on the tangent plane
11 - extruded/cut the slot using the tangent plane sketch
12 - then circular pattern the slot with success
TheCADWhisperer
I saw that you did not follow proper logic.
mcjj29909
Thanks for taking the time to help, Where was my logic in error, so can avoid repeat logic flaws.
TheCADWhisperer
Before I create a video - did you examine the file that I attached previously?
(BTW - it was "working" for you, but you had three bodies over top of each other.)
mcjj29909
Yes I viewed it. You had 1 body, mine had 3 bodies, 2 were create during the pattern command. So I guess the 3 bodies is the issue. If that's the case, what I did do to cause the pattern command to create 2 additional bodies?
