Issue defining motion link between two cylindrical joints.
alexanderhosford
alexanderhosford
I have two cylindrical links that I would like to move in unison. They are representations of stepper motors for the Z-Axis of a small CNC device.
Each motor component has a cylindrical join defined, that determines the rotation of the shaft.
The first video shows what is happening when the motion link is defined as part of a larger assembly.
As the assembly contains lots of components and joints, I was at first sure that I had done something wrong. I therefore created a second much simpler design, containing only two instances of the stepper motor.
The second video shows the same behaviour in the simplified circumstances, and how I am defining the motion link.
The behaviour occurs regardless of the order in which i define the joints or the values which I enter.
The joints behave as expected on their own, as do all other joints in the design.
There is a grounded component in the large assembly file, but not in the simplified test design that contains only two motors.
Although i have previously defined many motion links, this may well be the first time I have attempted to link two cylindrical joints to move in unison like this.
Is this a possible bug? Or am I doing something that does not make sense?
Thanks in advance for any assistance
jhackney1972
You will need to share your model to get an accurate answer.
John Hackney, Retired
alexanderhosford
Please find attached the simplified model in which the behaviour is occurring.
In any case, were you able to view the videos and see the issue I am describing?
jhackney1972
The issue you are experiencing is coming from the initial Revolve Joint on the motor.  You have it between the shaft and a body that is not either grounded or joined in the assembly.  I redefined this joint between the shaft and the mounting plate of the motor, a body I can easily ground or add a rigid joint to in the assembly.  Using the new revolve joints, the issue is solved.  Take a look at the Screencast.
alexanderhosford
Thanks John,
I had also gone down the route of redefining the joints on the motor component before I saw your reply, having made a test component up with just a gear and a shaft and subsequently being able to link just like I wanted.
I believe the rotation was defined around the rotor and the stator of the motor I had modelled, albeit some time ago so I'm not 100% certain.
In any case I have redefined all the joints now to be more sensible and in sequence - I am more methodical about this these days but the motor component is a few months old now and I fear may contain many of my older bad habits.
Thanks again for the assistance.
