Corrupt file
Corrupt file
simonrk
Message 1 of 23
Corrupt file
simonrk
all of my files are corrupt and impossible to open what so ever, pleas help.
Replies (22)
Message 2 of 23
RajkumarIlanchelian
@simonrk Can you please provide more information? What is happening? Are you seeing some errors on opening them? If so what errors?
Are you able to create new designs? Can you confirm if you are online?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 23
simonrk
So, I get the message that the files are corrupt and can’t be accessed. I have tried to download them and upload them but nothing seems to work. I can create a new file and design on that, but most of my files are all “corrupt” and I don’t know why.
Message 4 of 23
RajkumarIlanchelian
@simonrk Would you be able to invite [email protected] into that project, please? We can take a look to see what could be happening.
Autodesk Fusion
Join Fusion Insider
Message 5 of 23
jhackney1972
So what is the Fusion 360 version number you are using?  You can find this dialog box under help "?" and then About.  It may be your version is way out of date.
John Hackney, Retired
Message 6 of 23
simonrk
I am at 2.0.14793
Message 7 of 23
jhackney1972
That is the current version so that is not the issue.  Do you have one of the files that Fusion 360 says is corrupt that you can share?  If you have it on your hard drive, you can attach it to a reply post.  You can also go into your Web Database and download the file, then attach it.
Message 8 of 23
simonrk
I got the file but it seams to be a bit too large...
Message 9 of 23
simonrk
Message 10 of 23
dsouzasujay
Hi @simonrk
We are not able to download the file, from this Hyperlink (https://a360.co/3gdPWVa)
Could you please share a new link? or Would you be able to invite me (Sujay<dot>dsouza<at>autodesk<dot>com) to that project?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 23
simonrk
Message 12 of 23
dsouzasujay
Hi @simonrk
Yes, i'm able to download the file, We will get back once we identify the problem.
Please don't accept the solution until it solves your problem.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 13 of 23
simonrk
How can I avoid corrupt files in the future?
Message 14 of 23
jhackney1972
I was able to download and successfully open the file you posted to Dropbox.
Message 15 of 23
simonrk
Ok, soo… why am i not able to open the same file from my downloads?
Message 16 of 23
jhackney1972
I have no idea?  It took over 6 minutes to open it, maybe you are not patient enough.  Fusion 360 looks like it is locked up but it is still chewing away at it.  I save it to cloud drive if you need it.
Message 17 of 23
simonrk
I have tried to open it many times but the message I get is that the file can’t be opened and that it is corrupted.
Soo… where could I find it again?
Message 18 of 23
simonrk
Message 19 of 23
jhackney1972
We will try a Share first.
https://a360.co/3EHm799
Message 20 of 23
jhackney1972
Did the Shared link work, can you open your model?
