@simonrk Can you please provide more information? What is happening? Are you seeing some errors on opening them? If so what errors?
Are you able to create new designs? Can you confirm if you are online?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@simonrk Would you be able to invite [email protected] into that project, please? We can take a look to see what could be happening.
Autodesk Fusion
Join Fusion Insider
So what is the Fusion 360 version number you are using? You can find this dialog box under help "?" and then About. It may be your version is way out of date.
John Hackney, Retired
That is the current version so that is not the issue. Do you have one of the files that Fusion 360 says is corrupt that you can share? If you have it on your hard drive, you can attach it to a reply post. You can also go into your Web Database and download the file, then attach it.
Hi @simonrk
We are not able to download the file, from this Hyperlink (https://a360.co/3gdPWVa)
Could you please share a new link? or Would you be able to invite me (Sujay<dot>dsouza<at>autodesk<dot>com) to that project?
I was able to download and successfully open the file you posted to Dropbox.
I have no idea? It took over 6 minutes to open it, maybe you are not patient enough. Fusion 360 looks like it is locked up but it is still chewing away at it. I save it to cloud drive if you need it.
We will try a Share first.
Did the Shared link work, can you open your model?
