CANNOT MOVE OR ROTATE model on Mac trackpad
jeremyelford
Message 1 of 15
jeremyelford
only started to day. nothing has changed on the computer. CANNOT move or rotate using the Mac track pad. this happens on all files and even on the untitled file on open. have done a fresh install of fusion and issue remains. have spent hours trying to fit this issue.
Replies (14)
Message 2 of 15
ryan.bales
Autodesk Support
Autodesk Support
The first thing to check is that gesture navigation is on in the preferences:
Secondly, it almost looks like you are clicking in on the trackpad? If so Pan and Orbit do not use any click in on the trackpad, but rather use two finger gestures to pan, and shift+two fingers to orbit.
Ryan Bales
Fusion 360 Product Support
Message 3 of 15
crtrepan
Observer
Observer
Used to Fusion360 in Mac mini with mouse, new to 2023 MacBook Pro and did not know that.  Thanks
Message 4 of 15
chrischarlesworth
Same issue here, this used to work OK but not for a couple of months now.
Gesture navigation is on but two fingers on the trackpad only zoom the image and shift does nothing but stop the zoom.
Any other suggestions please?
Message 5 of 15
kinsleymark
Gestures stopped working for me on this latest release (MacBook Pro / M1 chip). They worked fine before (buggy, but worked mostly). But now no gestures work. I have to use my 3D connexion mouse to get work done.
Message 6 of 15
akos.wonerth
Observer
Observer
Same here, it stopped working couple of months ago.
Macbook Pro 15" Late 2015
Fusion 360 2.0.15995 x86_64 [Native]
macOS 12.6.4 (21G526) on MacBookPro11,4.
Message 7 of 15
Phil.E
Ensure in preferences that "use gesture based view navigation" is enabled.
Next:
1. In preferences, under Preview Features, turn on Native trackpad, and close preferences.
2. Try trackpad.
3. If it doesn't work, close Fusion (red x or command + Q)
6. Restart Fusion
7. Does the trackpad work?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 8 of 15
chrischarlesworth
You genius, thank you so much!
All sorted 🙂
Message 9 of 15
akos.wonerth
Observer
Observer
“Native Trackpad” in the Preview section solved the issue! Thanks a lot 🙏!!!
Message 10 of 15
Shithot
Thank you.
Was very frustrated by this issue but sorted now.
All the best,
Stephen
Message 11 of 15
prosto_lyubo
Observer
Observer
I wish there was an option to change controls scheme (rotation by double click on trackpad instead of drawing) - would be much simpler to use and the same as in almost every other 3D software in existance.
Message 12 of 15
poopatsy2WNM7F
Community Visitor
Community Visitor
so awesome. worked like charm... Great gratitude for you to take the time to post this solution... ❤️🙏😊
Message 13 of 15
bart_alarm
Native Trackpad does not show up in my Preferences, anywhere. I just updated to the latest version and have restarted Fusion,
Message 14 of 15
Phil.E
Thanks for asking.
Native trackpad graduated from preview and is now the full time trackpad experience in Fusion.
Are you unable to pinch zoom or orbit with the supported gestures? (here they are for reference)
One thing to verify, that you have gesture based view navigation enabled.
Does this help?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 15 of 15
bart_alarm
Awesome. Thank you!!
