Offset is inversed on symetrical objects (Problem with Curve's Normal ?)
Hi all,
I've a problem with defining an Offset for a curve.
I start from a curve I imported from an SVG file.
I then create a mirror symetry curve from the first one.
If I select the first curve and ask for an Offset of, say, 2 mm, the offset is on the outside of the curve.
If I select the second curve, and ask for the same Offset of 2 mm, the offset is on the inside of the curve.
Is this normal ?
Then, if I join the 2 curves (without the Offset) into one object, and ask for an Offset of the curve, depending if I click on the left or right initial curve, and ask for a 2mm Offset, the offset is inside or outside of the object.
If now I create a simple object, like a circle, and ask for an offset of 2 mm, the resulting circle is on the outside, as expected.
It looks like the "Normal" of one of the 2 curves (the mirrored one) is reversed.
Is my analysis correct ?
If yes, how can I reverse the Normal ?  Couldn't find the answer.
Thanks a lot
jeff_strater
yes, this is expected behavior.  The offset direction is related to curve direction (a curve doesn't really have a "normal"), and when you mirror a curve its direction will get affected.  There is no way to "reverse" a curve's direction.  The solution is to just negate the offset value of the mirrored curves to get the offset going to the correct side.
Jeff Strater
Engineering Director
Thanks for your quick and clear explanation.
