Cannot log into autodesk (fusion insider) - email changed
mtsraf
Observer Observer
Message 1 of 11
mtsraf
Observer
Observer
Fusion Insider was corrupted during an update and will not launch. I am not able to login since my email has changed. Can you anyone direct me to the correct resource to solve the login issue?
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@mtsraf @Are you not able to login because you are requested an OTP to login and you do not have access to your email inbox? (Or are you not able to login to only insider?)
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
mtsraf
Observer
Observer
Thanks for your quick response.
No only the account.
But the whole story is as follows:
I attempted to update Fusion Insider but the process crashed.
Then I attempted to login to download a fresh version and couldn't because I no longer have access to that email and will not receive the code. (I do not have a backup code 😞
So I created this account so I could post here.
Now I need to regain access to all my fusion files
Message 4 of 11
RajkumarIlanchelian
Message 5 of 11
RajkumarIlanchelian
@mtsraf @For production
Can you please follow from this thread? https://forums.autodesk.com/t5/fusion-support-forum/unable-to-access-my-autodesk-account-due-to-dele...
Autodesk Fusion
Join Fusion Insider
Message 6 of 11
mtsraf
Observer
Observer
Thanks for your messages.
That thread is not encouraging! 😯
I have the same problem that the last post. My university deleted my account and it cannot be recovered. I managed to get a production version of Fusion up but the Insider still fails.  I do need to update my email address. It seems that  @mathermann from the the thread you asked me to read is in the same position I am in.
When I attempt to create a ticket I get the spinning wheel which never goes to the next screen. See attached screenshot.
How do I get my account (and my files) back?
Message 7 of 11
RajkumarIlanchelian
@mtsraf Any success to log the ticket?
Autodesk Fusion
Join Fusion Insider
Message 8 of 11
mts749
Sorry for the delay. I did manage to contact support via chat and they were able to help me change my email address. It was a bit of an arduous process, but now all is well.
Martin
Message 9 of 11
mathermann
Hi @mts749
I’m glad to hear you were able to solve the issue. Could you please explain how you obtained support to change your email address? I’ve been facing the same problem, and any details about the process would be really helpful.
Thanks a lot!
Mathis
Message 10 of 11
RajkumarIlanchelian
@mathermann
I deleted the post. Will reply to your other thread.
Autodesk Fusion
Join Fusion Insider
Message 11 of 11
mts749
I solved the problem with a relatively lengthy chat back-and-forth between a support agent. She was very helpful and after a number of trial and error steps, we solve the problem.
I suggest that you start a support chat to explain the situation.
