Solid Fillet Tool giving inconsistant results / wrong result
TSSmith7
TSSmith7
Hi all,
I'm trying to create pockets in plate-like parts that can be machined with a mill.  I have created an add-in that creates pockets in the part that don't have filleted corners from some sketch geometry.  The resulting pockets look like:
I want to fillet all the inside corners of the pockets for milling but I get very strange results that are not even reproducible.  Here is the result trying to fillet with a 0.3in radius:
Sometimes a selected edge will give an error and if I unselect it then reselect it the error goes away.
I would like to fillet this part with a 0.135in radius which (this time) gave:
with the red circled corner being the only correctly fillet corner.  Another time I tried this same model it did two of the corners correctly.....
Model is attached.
Thanks for any help
davebYYPCU
You gotta give Fusion a fighting chance, the internal corners at the rectangle border would never get a cutter in there.
eliminate those with small edit and works as expected.
Might help...
TSSmith7
Yes thank you I do realize that would solve the issue manually.
I am trying to have this occur automatically with an Add-In.  I realize also that this is a somewhat special case for the fillet tool.
This type of geometry occurs very regularly in the Manufacturing Workspace however.
Maybe someone knows if it would be possible to use a 2D Contour operation and then grab the resulting geometry and put that into a sketch?  Hopefully without actually switching the user interface to the Manufacturing Workspace and then back to the design workspace.
Thanks again.
TheCADWhisperer
@TSSmith7
With all this symmetry I would have modeled one portion using Thin Feature Extrudes and then Pattern the geometry, but I don't know where you are going with your add-in.
Also, you have a little piece of rubbish in your Sketch1.
Doubt it has anything to do with the issue, but for an add-in I would definitely want clean geometry.
davebYYPCU
@seth.madore did you see this?
seth.madore
Technically, one could create toolpaths and use a .dxf post processor to output a file that could be reimported into Fusion. Otherwise, there's not really any other mechanism to do what you're hoping.
Seth Madore
