Bug when using rectangular pattern on hole
ryan_thaler
ryan_thaler
im trying to create a hole pattern and for some reason, im getting a small bug. I made the hole and used a rectangular pattern, shown below, and for whatever reason, the holes on the right side show a surface above where the hole is. Ive tried selecting optimized, identical and adjust with no success. Am i missing something? thanks
jeff_strater
Hard to say what I'm looking at in those images.  Can you share the model here?  (export as F3d and attach it to your next post)
Jeff Strater
Engineering Director
TheCADWhisperer
@ryan_thaler
Do you have the correct component active?
Attach your file here and end all doubt.
ryan_thaler
@TheCADWhisperer @jeff_strater i closed the file and tried opening it again. now the left side had the bug. i did that again and there's no issue. so i think it's just a compensation for rendering. this is part of a rather large assembly so makes sense.
g-andresen
Please share the file then we can analyze the situation.
File > export > save as f3d on local drive  > attach it to the post.
günther
