Bug CAM: Pattern always active, even if you only select some operations in a pattern for export
raven2DRN4
raven2DRN4
Translated from German report:
https://forums.autodesk.com/t5/fusion-360-deutsch/bug-cam-muster-immer-aktiv-im-pp-egal-was-selektie...
If you select one or more operations within a pattern and export with Post Processor - the Selected Operations are with pattern and not only themselfs like before and expected.
Expected: Only the selected operations get exported like it was in the last years.
Cave_Master
What you are seeing is by design and what you expect to happen is how the software used to work.
Here is some more context.  https://forums.autodesk.com/t5/fusion-360-manufacture/operations-within-component-pattern-post-with-...
raven2DRN4
Thank you for the link - exactly that.
So no bug.
But it was better as it was before.
