Unable to open .prt file in Fusion 360
themaninthesuitcase
Message 1 of 9
themaninthesuitcase
I am trying to open/import a .prt file but I am unable to do so following the instructions posted:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
The first screen shot there shows .prt as supported and https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fil... also lists this as supported.
However when I chose File > Open "All supported types" does not list *.prt, and it's not available in any other options.  If I manually type the extension then I get an error "This file type cannot be opened."
If I try to do an upload import the file sits in my library with a yellow inverted T icon and only opens to a web view.
Has support for this type been removed?
Fusion is fully updated and I am using a valid Personal license.
Replies (8)
Message 2 of 9
tallisb
Hello-
Do you know if you are running a full subscription of Fusion 360, or are you on a Personal License?  You can check by going to the Help Menu in the upper-right of Fusion 360 and select "About".  This will bring up a dialog and it will list what you have next to "Active Plan:"
Here is a document that explains the differences between the Personal, Startup, Commercial, and Education licenses:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Fusio...
Brad Tallis
Fusion 360 Technical Specialist
Message 3 of 9
davebYYPCU
Personal Licence suffers those restrictions, with external files.
Might help....
Message 4 of 9
themaninthesuitcase
Okay it's a personal license issue, but those help articles didn't mention that limitation.
I'll find another way then.
Thanks.
Message 5 of 9
Michael_PageHWSYT
Hello Guys - I am having the same issue; I cannot open a PRT. File. My active plan is Subscription. How do i open a PRT.FILE?
Message 6 of 9
TheCADWhisperer
@Michael_PageHWSYT
Can you zip and Attach the file here?
What CAD program generated the file?
Message 7 of 9
Michael_PageHWSYT
Good morning.
The Cad program was generated on NX Unigraphics (PRT.FILE)
I also can not open a DWG - I will attach this aswell.
Kind regards.
Michael Page
Message 8 of 9
TheCADWhisperer
@Michael_PageHWSYT
To attach a file you must go to the web-based forum to reply, not by an email reply.
Message 9 of 9
Michael_PageHWSYT
Hello.
How do I find the web-based forum. I am still learning the Fusion software.
Regards.
Michael.
