Appearances and Physical material command not working
Message 1 of 13
After last update, in my computer, 'appearance' and 'physical material' commands are not working.
I tried re-installing Fusion360. The problem still persists.
Whenever I run either of the commands. Fusion stops responding.
I waited for 1+ hour once for it to respond. It did not respond. I had to force close it.
So...
I've to force close fusion 360 every time I accidentally try to run commands 'physical material' and/or 'appearance' command. because fusion stops responding after starting those commands.
Replies (12)
Message 2 of 13
Same problem is with me... Unable to open appearance tab
Message 3 of 13
But which is the file u have uploaded here, zip file?
Message 4 of 13
Yeah zip file. I just added it here if anyone can look at it and find what exactly is the problem. You can generate it for your software from 'help' dropdown from Fusion360.
Except these 2 commands (appearance and physical mistrial) evening else is also working for you?
Can't at all change material and appearances of design.
Message 5 of 13
Exactly the same problem since friday 08
Message 6 of 13
RajkumarIlanchelian
We deployed an update today that has a fix for this. Please update to the latest version and let us know if this issue has been resolved for you.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 7 of 13
Thanks, the issue has been fixed.
Message 8 of 13
I updated software. The issue is still not fixed for me.
I'm not able to open appearance and physical material command at all. And if I accidentally try to open it, I've to force close fusion 360 and restart it.
Message 9 of 13
RajkumarIlanchelian
For anyone that are still crashing using Appearance, we have reproduced this issue and are actively working to find root cause and come up with a fix.
We sincerely apologize for the inconvenience and will provide an update as soon as we have a fix.
Autodesk Fusion
Join Fusion Insider
Message 10 of 13
RajkumarIlanchelian
Can anyone still crashing please check your system locale and tell us what it is set to? Also can you change this locale to another setting and then restart the machine, launch Fusion 360 and tell us if you experience the crash?
We greatly appreciate your time and patience and help while we figure this one out.
View the System Locale settings for Windows
  1. Click Start, then Control Panel
  2. Click Clock, Language and Region
  3. Windows 10, Windows 8: Click Region
    Windows 7: Click Region and Language
    Windows XP: Click Regional and Language Options
    The Region and Language options dialog appears.
  4. Click the Administrative tab
    On Windows XP, click the Advanced tab
    If there is no Advanced tab, then you are not logged in with administrative privileges.
  5. Under the Language for non-Unicode programs section, click Change system locale and select the desired language.
  6. Click OK
  7. Restart the computer to apply the change.
Autodesk Fusion
Join Fusion Insider
Message 11 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi all,
We have found a workaround and I have posted it in the below link:
https://forums.autodesk.com/t5/fusion-360-support/attn-workaround-for-appearance-hang-crash-found/td...
Can you guys let me know if this works when you try this? Please note that for Windows 7 you need to change the system locale and the Format (see my two screenshots in the post).
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 12 of 13
Sir, how to update the fusion 360 to the latest version?
Message 13 of 13
innovatenate
Autodesk Support
Autodesk Support
Fusion should notify you when an update is available. See the below screenshot for more information. To update, select the Restart Fusion 360 link.
If you're running Fusion via a lab installation, the network administrator will need to update the software. See the below link for more information.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
If you're not seeing this, you can upload the Help > Diagnostic log files from your computer and I will be happy to take a look. Usually the fastest solution is to use the Fusion Cleaner tool to remove the existing installation and re-installing. I hope this helps!
Nathan Chandler
Principal Specialist
