saving as dxf
saving as dxf
r.birza
Observer Observer
saving as dxf
r.birza
Observer
Observer
when i will save my sketches to dxf , the sketch is not similar to the sketch.
in another project it will work , when I am doing the same steps.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @r.birza,
Welcome to the Fusion 360 Community!
Can you expand a bit on what you are seeing? Perhaps provide some screenshots comparing the DXF vs the Fusion sketch? I am confused as to what might be happening.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
r.birza
Observer
Observer
http://autode.sk/2AsRHb4
i hope you can see what i am doing wrong
greetings Ronald
James.Youmatz
Autodesk Support
Autodesk Support
Hi @r.birza,
That looks "correct" to me as far as I can tell. The reason I say this is that when you created a sketch on that face, the outline of the 3d geometry is auto-projected (based on your preferences). This is all that is contained in the sketch. What you see in the background is either other geometry or other sketches. To isolate this - turn OFF the visibility of everything but the active sketch. Then you will see that what is contained only in the sketch you are looking for. My suggestion is to use the Project command from the Sketch menu to project all wanted geometry for the laser cut into the active sketch.
James Youmatz
r.birza
Observer
Observer
Thanks fort the hint,
I sent you the dxf file it is not good. Can you gif me another suggestion
Greetings ronald birza
James.Youmatz
Autodesk Support
Autodesk Support
Hi @r.birza,
Can you share the original model with me so I can create the DXF file myself. Also what are you looking to have in your DXF file that is not contained in the sketch that you are saving?
James Youmatz
r.birza
Observer
Observer
Some rectangles are not in the dxf file, there is only a line.
I , ve shared the sketch tot he fusion 360 gallery, is that enough for you?
Greetings ronald
