3 D Modelling first impressions..
stephen_john614EWYV2
Message 1 of 8
  1. When moving from 2d CAD drawings to 3 D modelling what top 5 things made you happy with the transition?
Accepted solutions (4)
Replies (7)
Message 2 of 8
dsouzasujay
Hi @stephen_john614EWYV2
Thank you for your question. To better assist you, may I ask what specific aspects you are most interested in regarding the transition from 2D CAD drawings to 3D modeling? Understanding your focus will help me provide more relevant and detailed feedback
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 8
TheCADWhisperer
1. Single source of truth.
2-5. See #1.
Message 4 of 8
Hello Sujay,
My particular interest in 3D modelling as opposed to 2d Autocad is the scope to be able to produce what's in my head into a 3 D model, and my no. 1 love of 3 D programs like fusion is similar to the artist with his/her eazel, brushes, paints, ie being able to put your ideas into 3 D space anytime any where, and continue to produce and make in life.
Hope this helps for your inspirational ideas in your 3 D world,
Blessings
Message 5 of 8
Sounds perfect.....
Message 6 of 8
Sounds perfect, thanks
Message 7 of 8
dsouzasujay
Hi @stephen_john614EWYV2 ,
Thank you for sharing your interest in 3D modeling with Autodesk Fusion. I completely understand the joy of being able to turn ideas in your head into tangible 3D models. To help you achieve this, here is a step-by-step guide on how you can bring your concepts to life using Fusion:
  1. Insert the Canvas:
    • Go to the Insert menu and select Canvas.
    • Choose your image file (a sketch or photo) from your computer.
  1. Position the Canvas:
    • Select the face of your model where you want the canvas to appear.
    • Adjust its position, scale, and orientation to match your needs.
  1. Calibrate the Canvas:
    • Right-click the canvas and select the Calibrate option.
    • Click two points on the image and enter the actual distance between them to scale the entire image accurately.
  1. Sketch on the Canvas:
    • Select the canvas and choose to create a new sketch on it.
    • Use tools like the Sketch or Spline tool to draw over the image, tracing the outlines of your idea.
  1. Create 3D Models:
    • Once your sketch is complete, use the sketch to create a 3D object.
    • For example, the Extrude command takes the 2D sketch outline and gives it depth to create a 3D body.
  1. Refine the Model:
    • Continue to add details, symmetry, and other features.
    • Ensure the final 3D model is proportioned correctly and ready for manufacturing.
By following these steps, you'll be able to take your conceptual sketches or photos and transform them into detailed, manufacturable 3D models in Fusion.
Here is a video from AM Custom fab
( Fusion 360 ) How to Convert A Photo to a Cnc File using Fusions Canvas Tool. (Langmuir Systems) - ...
Hope this helps you get even more creative and productive in your 3D modeling journey!
Few more posts:
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 8 of 8
Many thanks Sujay...
I aim to effectively produce many 3 D models from tracing around inserted photos using poly line feature.... Circular objects and using revolve feature seems the easiest way to create 3 D models at the moment... More to come I expect... Blessings
