Intersecting flanges in flat pattern
spatterwelds
spatterwelds
See attached. If I change the the 2nd flange angle to more than 21 degrees the problem goes away if it is 21 or less it creates impossible flanges. Did I do this wrong?
jhackney1972
Any angle above 22 removes the Miter on the last Flanges so all you have to do is remove the miter on the last flange command.  Video will explain.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
(view in My Videos)
John Hackney, Retired
spatterwelds
I guess I should have been more specific, I need the miter command to be on for a third flange. See attached
I can't see a video attached
jhackney1972
With a miter on the third flange, there will be interference in the flat pattern so there is no solution.
