Intersecting flanges in flat pattern
welderQMQFT
welderQMQFT
See attached. If I change the the 2nd flange angle to more than 21 degrees the problem goes away if it is 21 or less it creates impossible flanges. Did I do this wrong?
jhackney1972
Any angle above 22 removes the Miter on the last Flanges so all you have to do is remove the miter on the last flange command.  Video will explain.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
welderQMQFT
I guess I should have been more specific, I need the miter command to be on for a third flange. See attached
I can't see a video attached
jhackney1972
With a miter on the third flange, there will be interference in the flat pattern so there is no solution.
