OP-Finder Add-in Idea
Hi! So I'm trying to use Claude to create a Fusion 360 Add-in Called "OP-Finder". I feel like the idea is simple and I have a partially working add-in. Basically, I want to mimic the feature from the Design Workspace that when you click on a model surface, face, fillet, etc it will show you where it's at in the design timeline. So what OP-Finder does is when you're in the Manufacture Workspace and you click on a model surface it will highlight in Blue (as if you left clicked once) the tool path machining this feature or face. I'm trying to speed up the process of looking for operations in large programs that has multiple folders of tool paths (mainly 5 Axis programs in my case). For example, if I click on a 4-40 hole then it will show me where those tool paths are quickly in the setup that is currently active. If I could get some help with bringing this idea to life that would be awesome! I attached a screenshot of what I've got so far on the holes side of things. Currently, when I select a pocket it shows all of the other toolpath operations other than holes. Let me know what you think!
1 Comment
andrade_david
Status changed to: Archived
Hey @Jake_devega, thanks for the idea! This is the Fusion Operations Ideas forum, not Fusion. There is no Ideas board for Fusion, but we do have an Insider program where you can provide feedback: https://www.autodesk.com/campaigns/fusion-360/insider-program
Thank you
