Consuming Products with Variable Parameters
I have to receive products in with a variable parameter. However, when it comes to consuming those products the parameter does not follow the product, nor is asked on the mobile app when the worker is confirming the consumption.
In my situation I had to consume 3 of the same part number with all different variable parameters to a Production Order and then had to unconsume 1 of the products from the order, with that I had to do some researching to figure out the correct product.
1 Comment
andrade_david
Thank you for your idea, @jennyYTSPP
I made a minor change on your text from "parameters" to "variable parameters", so that other users can more easily find this idea. I also believe that it's not just a matter of the variable parameter "following" the product when it is consumed, but also ask workers what was the product parameter that was consumed (in case multiple exist).
