Fusion Manufacture
zero position
2 REPLIES 2
conjured2018
154 Views, 2 Replies
zero position
Hi, I use near left corner on my 4'x4' cnc bed. I would like to use dead center or 24'' x 24''. do i just set up mill at middle and post process as normal? I question that code will run negative and wonder if this matters.
thank you, JR
2 REPLIES 2
jscott6SWZG
in reply to: conjured2018
When you create a new setup.  Under stock.  You get to select the origin.  Ie where the machine needs to be centered.  Pick a stock box point or a model point. If it is top center then fusion will figure it all out
conjured2018
Thank you
Technology Administrators
