Hi, I use near left corner on my 4'x4' cnc bed. I would like to use dead center or 24'' x 24''. do i just set up mill at middle and post process as normal? I question that code will run negative and wonder if this matters.
thank you, JR
Solved by jscott6SWZG. Go to Solution.
When you create a new setup. Under stock. You get to select the origin. Ie where the machine needs to be centered. Pick a stock box point or a model point. If it is top center then fusion will figure it all out
