Fusion Manufacture
When will custom form mills be supported?
18 REPLIES 18
Message 1 of 19
CGPM
588 Views, 18 Replies
I would just like an update/ your opinion on when custom form tools will be supported, or at least where things are at today.  I NEED to be able to import one to run a simulation to make sure it will do what I want.  My brain simulator just isn't sure that what I need can be done with one tool.  I have designed it, got 2 quotes, and then froze because I am just not sure it will work and would hate to spend $600 to find out it doesn't.  Currently doing 4 passes with 2 tools and want to do 1 pass with 1 tool so really motivated to get that custom form tool for this open ended production job.
18 REPLIES 18
Message 2 of 19
daniel_lyall
in reply to: CGPM
If you know someone who has Inventor HSM you can get them to setup the tool, then you can import it into fusion. Someone should do this they could make money out of it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 19
I'm curious if the Simulation will do it's job though, as it's now a form mill. Of course, you could compare against the modeled features and inspect visually for form and fit.
If you have a sketch you could send me, I could try it in Inventor HSM and send it back to you
On another note; I think we are long overdue for an update on what's going on with the Tool Library and everything that entails, wouldn't you agree @al.whatmough I know it's been mentioned on more than one occasion that a blog update may be in order. Perhaps after the hectic AU is over we could possibly see some comments and direction?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 4 of 19
CGPM
in reply to: LibertyMachine
I would be thrilled to send you anything you want but need to know exactly what and how you want it?  The only thing I don't want to share publicly is the clamp design of the fixture but would be happy to send you the whole Fusion project, or invite you to it, if that would work, just don't share it.  Or I can just send the tool and part.  It isn't that complicated but I am not sure how the top and bottom chamfers will work out when I chamfer the corners of the bars.
Message 5 of 19
LibertyMachine
in reply to: CGPM
Understood. PM sent
Seth Madore
Message 6 of 19
LibertyMachine
in reply to: CGPM
Well, I'm not seeing this working. I made a for tool in InventorHSM and exported the library. While I was able to import the library into Fusion, the tool isn't displayed in the Fusion Tool Library. Because it's a Form Tool and there are no filters for that, it's simply not displayed. At least that's my theory. If anyone could prove me wrong I'd be more than happy to see it actually work
Seth Madore
Message 7 of 19
Steinwerks
in reply to: CGPM
I've made it work in the past via HSMWorks. I'm play with it a little tonight. My previous form tool should still be in my cloud library too so I'll look for it.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 8 of 19
daniel_lyall
in reply to: Steinwerks
@LibertyMachine thats where I saw it HSM not Inventor my bad
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 19
Steinwerks
Well it seems to be very oddly official: Fusion won't support Inventor HSM form tools:
Edit: I thought I had an older HSMWorks form tool in my library but it appears I do not. I'll play with it tomorrow over lunch though and see if it still translates.
Neal Stein
Find me on:
Message 10 of 19
bensbenz
I use some custom form tools on my machine and I use fusion. Since I cant see what it looks like in sim, I created the tool as a model, used the bottom of the tool as a reference and created a sketch to use in CAM for how I wanted the tool to work. In the tool library I created a tool with the general shape but with the exact OD of what the bottom of the real tool is  (matches the model I made). I setup a contour using my sketch as the selection, so I know exactly where the tool is going to go and how it interacts with my part. I have done this with 2 different tools and it has worked perfect each time. So while your not getting an actual simulation it can still be done and you have a pretty good idea how its going to work.
Message 11 of 19
RandyKopf
in reply to: bensbenz
@bensbenz
That is a smart and effective work around thank you!
I've done this type of thing over many years and my CAM systems using a Cross Section of the part VS  a Sketch of a Tool to precisely calculate areas I want added control. It's like a graphical form of calculus for smart machinists. At one time I was actually featured in a Tooling and Production article that showed how to exploit CAD to enhance CAM.
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
Message 12 of 19
Steinwerks
in reply to: RandyKopf
The "program to the tool tip" has been the workaround for over two years now. This doesn't help with simulation, or rest machining, and asking users to constantly work around limitations not found in even software like BobCAD-CAM is pretty sad IMO.
What I would like to see is a sketch dialogue in a Form Tool creation menu. Sketch it out right in the Tool Library, select or create a control point, select a revolve line, and done.
Or just make it like many other packages do and import a model. This should be easy-peasy for something as internally connected as Fusion.
Neal Stein
Find me on:
Message 13 of 19
bensbenz
I agree 100% but if you need to get the part done now its just a way to do it. I wish we had many of the basics that other software's have, but we have basic 5 axis now so there's that Smiley Indifferent!
Message 14 of 19
bensbenz
That's sounds neat. I cant imagine doing anything I do without the tools we have available today. I'm new enough to design and machining that CAM without integrated CAD doesn't even compute in my brain LOL.
Message 15 of 19
RandyKopf
@Steinwerks
I completely agree with your assertion. I use Mastercam for Solidworks at work and it supports a sketch to be used as a custom tool OR solid model to be used. But even with what I have it is some what limited.
In my older days programming in both Pro/Engineer NC and UGII I could do a SKETCH FORM TOOLS ON THE FLY. But wait there was more... Way more...
AND
More importantly the sketch allowed for MULTIPLE TOOL CONTROL POINTS. Each would influence the tool path calculation. In one tool sketch you could have the following set.
1) Standard Control point on tool axis C/L and TIP.
2) Control Point on a point on side of tool at contact of geometry. (correlates to an edge on a thread model OR Multi Tool Chamfer Point)
3) Shifted points to simplify setup. This allows setting off the tool tip but the math is shifted to some contact point.
4) As many other control points to add if you need them...
EDIT: A good example would be today's multi function tools, see added tool graphic
In each of these cases the tool path is calculated and output differently to allow driving off existing math OR to simplify setups.
AND
Most importantly each point type was available for each new operation within the same setup. And each would allow the tool to act independent of an prior existing operation. Again calculating unique to that operation based on the Form Tool Control point selected.
AND
Each one could have a unique Tool Offset number assigned to match further refinement on the Control.
AND
All of that was in conjunction with the various type compensation methods like computer, wear etc...
And this is why I made the prior assertion in reply to @bensbenz that I can still do crazy stuff just by doing sketch work.
Randy Kopf
Message 16 of 19
CGPM
in reply to: CGPM
Thanks for all of your interest and to Seth and Steinwerks for trying to do it.  Programing the path is dirt easy, I could hand code it if I needed.  Here is a photo of the tool to better describe the issue.  I cut the end of 1/4" x 1" bars with this profile which includes the small chamfers top and bottom and .03" chamfers on the corners of the bars.  I would really like to know the .02" top and bottom chamfers will do their cuts when the tool does the .03" chamfers on the corners.
Message 17 of 19
Steinwerks
in reply to: CGPM
I can confirm that importing form tools from HSMWorks no longer works either. Bollocks.
Neal Stein
Find me on:
Message 18 of 19
daniel_lyall
They seem to do that quite often something from inventor HSM or HSM will work with fusion then they kill it.
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 19
CGPM
in reply to: CGPM
Is this so far off the radar that nobody from Autodesk is going to chime in?
Bump, bump.
Technology Administrators
