Seems a spline curve will not allow me to set tabs. Is this not allowed or another bug? What am I missing here?
Solved by MattWynn. Go to Solution.
I dont believe tabs will work with splines. Not a bug, just not a supported feature.
Without your geometry I can not say exactly. But I can say some general things about 2d contour and 2d profile tabs:
Improving tabs is one of my goals.
Thanks all for the comments. Matt touched on the spline subject and
with a little bit of brain work I believe I found a work around that does
the trick.
Don
see Solved:Tab Positioning At Points cannot select points on spline edge of part for workaround
