How can i use an existing tool library?
I have a library in the dropbox and i want to share it with my laptop.
But i saw no buttons to open an existing library.
First off, in the Tool Library window, You have two choices, you can either Right Click on an exisiting folder, like My Libraries, and choose 'Add Library Folder ...' and point it to your dropbox folder that contains your Library, or, choose Add New Library, give it a unique name, and the Right click the newly created empty Library, and choose 'Import Tools from Library ...' and then navigate to your custom Library to import tools from it.
After writing all that, I now see you're running a Mac, and I'm sure there where a few problems with Libraries under Mac OS. 😞
HTH 🙂
Will the bugs - that i wrote above - fixed in an earlier bugfix release?
Drag and drop is not implemented yet, but was unfortunately left discoverable in the current version - it will be available in a future version.
Could you be more specific as to which values does not show up correctly in the tool table ?
Kind regards,
Peter
