Upon opening the Tool library we are getting booted out of Fusion ( I posted the same issue 2 days ago)
Solved by mbulgerDHJU5. Go to Solution.
What version do you have? Current version here is 2.0.11680
Have you tried accessing your Autodesk account and re-downloading your software ?
Have version 2.0.11685 after update. Hope it corrects issue. (3 work stations were having same issue)
Have just tested opening the Tool Library on 3 computers here with versions 2.0.11680, 2.0.11684 and 2.0.11685 and have no issues.
All three computers are "stand alone" and each has it`s own Internet access although they are usually used in "offline" mode but were connected online for the test 🙂
Are your 3 work stations on a local network to a server on your premises ? If so then this could be where the issue is located, have you tried connecting one of them direct to the Internet and checking if the issue is still present ??
