Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Tool Library Issues
3 REPLIES 3
mbulgerDHJU5
166 Views, 3 Replies
Tool Library Issues
Upon opening the Tool library we are getting booted out of Fusion ( I posted the same issue 2 days ago)
3 REPLIES 3
engineguy
in reply to: mbulgerDHJU5
@mbulgerDHJU5
What version do you have? Current version here is 2.0.11680
Have you tried accessing your Autodesk account and re-downloading your software ?
mbulgerDHJU5
in reply to: engineguy
Have version 2.0.11685 after update. Hope it corrects issue. (3 work stations were having same issue)
engineguy
@mbulgerDHJU5
Have just tested opening the Tool Library on 3 computers here with versions 2.0.11680, 2.0.11684 and 2.0.11685 and have no issues.
All three computers are "stand alone" and each has it`s own Internet access although they are usually used in "offline" mode but were connected online for the test 🙂
Are your 3 work stations on a local network to a server on your premises ? If so then this could be where the issue is located, have you tried connecting one of them direct to the Internet and checking if the issue is still present ??
Technology Administrators
