Since the update I've noticed on several models that I can no longer place tabs in certain places on a 2D contour.
Demonstration video: (I'm unable to put a table on the 4th curved side)
I've seen this problem if the edge is a spline, is the part imported or done in Fusion?
In the example below the one on the left is an arc and I can add a tab, the other 2 part use a spline and a conic spline and you can't add tabs.
My file's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Hey Mark, no not imported, was made in the same drawing. But yes, that particular curve is the result of the a spline (offset I think too). I'm seeing similar on other splines in the file.
I actually thought this problem was fixed at one point, it was giving problems cutting out fonts at one point. Although thinking about it a bit more it used to crash Fusion if you used By distance and there was a spine in the chain so this might be the first time this bug has come up.
As a workaround if you go to the model workspace, edit the sketch that created the extrusion and add points where you want the tabs you can select them in the CAM workspace.
Mark
Mark Hughes
