Fusion Manufacture
Radius compensation
4 REPLIES 4
PvdBos
837 Views, 4 Replies
Radius compensation
I wonder where I can find the option to make the G-code with Radius compensation ON in the CAM mode
so that I can change the mill Radius in the tool library in Mach3.
thanx..
4 REPLIES 4
Steinwerks
in reply to: PvdBos
Use "In Control" compensation.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
PvdBos
in reply to: Steinwerks
Oke but where can I find this option?
Steinwerks
in reply to: PvdBos
It only exists for finishing operations. HSM doesn't use cutter compensation for most of its toolpaths. Are you using regrinds or changing tool sizes often?
Neal Stein
Find me on:
PvdBos
Oke thanks I found it when I use "Finishing passes"
Technology Administrators
