I wonder where I can find the option to make the G-code with Radius compensation ON in the CAM mode
so that I can change the mill Radius in the tool library in Mach3.
thanx..
It only exists for finishing operations. HSM doesn't use cutter compensation for most of its toolpaths. Are you using regrinds or changing tool sizes often?
