When I switch between design and manufacture a number of my bodies move.Go back to design and they in the original place. How can I stop this from happening?
https://knowledge.autodesk.com/community/screencast/7c4de6c8-99bf-4453-967a-c41a6139b677
Mark
Solved by seth.madore. Go to Solution.
Joints. You have a ton of "Move" commands and the CAM environment doesn't handle that too well.
The other thought and area to look at is your Manufacturing Models. What's contained in those, I see you have it active.
the move cmds were to manually nest for the cut. No joints in this model as its simple furniture. ITs likely it was because I had tried to use the arrange / nesting functionality unsuccessfully.
NVM as I have now re-nested on fresh design. Once the nesting functionality matures a bit I will give it another go.
Mark
Right, but what I'm getting at is there have been reports in times past of people with a slew of Move commands and parts or toolpaths going out of whack when moving to the manufacture space. Joints isn't just used in assemblies, but also to properly position parts...perfectly.
