Fusion Manufacture
Strange Behaviour Since Update
1 REPLY 1
david.quayle
124 Views, 1 Reply
The first time I used CAM since the update and I have experienced issues.
CAM 1 shows the screen with the Setup Selected, all normal, except of course for all the Warnings mostly dueto Cant Plunge Outside Stock.
CAM 2 shows what happens when I select the 1st Operation, everything goes green and the just like it would if I was in Simulate with Stock selected, annoying
Cam 3 shows all of the warnings in the Operation 2, not sure what the No Passess To Link is all about, that normally stops everything.
The real problem came when I actually tried to run the Operation 2 it was like the program had lost track of the heights and proceeded to route unwanted grooves everwher it went, basically didn't lift between cuts. I ran the Operation in simulate and all looked fine! I will sacrifice some more material tomorrow and report back.
1 REPLY 1
seth.madore
in reply to: david.quayle
Regarding the green display, that is your "In-Process Stock" being displayed. This was added in the last update. If you wish to turn off display, you can toggle this button here:
For the 3rd point, can you export the .f3d and share your file?
Seth Madore
Technology Administrators
