Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Switch between design and manufacture and all my bodies move
3 REPLIES 3
245 Views, 3 Replies
When I switch between design and manufacture a number of my bodies move.Go back to design and they in the original place. How can I stop this from happening?
https://knowledge.autodesk.com/community/screencast/7c4de6c8-99bf-4453-967a-c41a6139b677
Mark
3 REPLIES 3
seth.madore
Joints. You have a ton of "Move" commands and the CAM environment doesn't handle that too well.
The other thought and area to look at is your Manufacturing Models. What's contained in those, I see you have it active.
Seth Madore
in reply to: seth.madore
the move cmds were to manually nest for the cut. No joints in this model as its simple furniture. ITs likely it was because I had tried to use the arrange / nesting functionality unsuccessfully.
NVM as I have now re-nested on fresh design. Once the nesting functionality matures a bit I will give it another go.
Mark
seth.madore
Right, but what I'm getting at is there have been reports in times past of people with a slew of Move commands and parts or toolpaths going out of whack when moving to the manufacture space. Joints isn't just used in assemblies, but also to properly position parts...perfectly.
Seth Madore
