Hi everyone, I am having an issue with the generic Mazak mill post. I have my tapping cycles turned on to use feed per revolution and when I create the NC program, I have use pitch for tapping turned on. But when it posts it is saying this post processor does not support feed per rev. Am I doing something wrong or is it the post? If this is a common problem would anyone know what to change in the post?
Hi
I have tried this with several versions of the Mazak Post and it appears to work correctly.
What version of the Generic post are you using?
There was a new version released yesterday so it might be worth trying that.
If that still isn't working can you share a sample part that exhibits the error.
Export it from Fusion and attach to a reply here.
I am using the Mazak mill post version 44131. The feedrate is correct as far as the pitch but it refuses to insert G95 instead of G94. I know its a simple fix but something this simple should be correct.
N10 G90 G94 G17 G49
N15 G20
N20 G53 G0 Z0.
(TAP 6-32)
N25 T4 M6
N30 S1000 M3
N35 G90 G94 G17
N40 G54
N45 M8
N50 G0 X0.1784 Y-0.4687
N55 G43 Z0.64 H4
N60 G0 Z0.24
N65 G98 G84 X0.1784 Y-0.4687 Z-0.38 R0.2 F0.0312
N70 Y-1.2187
N75 G80
N80 G0 Z0.64
N85 M5
N90 M9
N95 G53 G0 Z0.
N100 G49
N105 M30
I just tried out the code in the machine and to my surprise it seems like the G84 defaults to feed per rev without the G95 present. I used the same code I replied with, and the RPM was 1000 and the FPR .0312. While watching it the active feedrate became F31.2. I didn't know it could do this and since it did, I am not sure why fusion was giving me the alarm that says it can't support it.
