Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Open pocket toolpath
5 REPLIES 5
jlucasemail
318 Views, 5 Replies
jlucasemail
Is it possible to build a toolpath for an open pocket without cutting around the whole object?
A trace toolpath works but without stepdown or finish pass!
I did it by temporarily extending the diameter of the disk so I could use a 2D pocket totally enclosed by the body.  Works but does not seem satisfactory.
Labels (2)
5 REPLIES 5
johnswetz1982
in reply to: jlucasemail
johnswetz1982
When picking the contour you can either hold control and pick the individual segments or you can select the outline/perimeter then long click it again and you will get a popup dialog box when you can accept/reject and pick wither you want an open contour or a closed contour.
iporter6
iporter6
select the 2 lines and the arc by holding "Alt" and clicking the edges.
seth.madore
seth.madore
Well yes, but no. Press the ALT key. Select the first edge of the slot. Select it again, add on to the chain. Fusion doesn't always properly handle multiple chain selections like this (in the manner outlined by @iporter6 ). It's best to feed it proper selection information
Seth Madore
Seth Madore
jlucasemail
jlucasemail
That did it.  Thanks.  Had to set sketch like this to clear the outer corners of the pocket:
seth.madore
seth.madore
Did you try turning on Stock Contours? That usually does it for me 🤔
Seth Madore
Seth Madore
