I'm just trying to get multi axis to work and I'm not making much progress. I'm just trying to machine the o ring groove in the top of the part.
No matter what I try I get the warning "No passes to link" and "Empty Tool path".
I've attached the file.
Thanks.
Solved by LibertyMachine. Go to Solution.
You might be better off using the 2D toolpaths with Wrap turned on
See attached file
