Can anyone help with the correct machining strategy for cutting out oval pockets in a part? I have tried 2d and 3d with no success, I am getting empty toolpath or no passes to link. Please see the attached file.
Solved by jhackney1972. Go to Solution.
Solved by brad.francola. Go to Solution.
You can also use 2D Pocket for these slots. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thanks for your help, after downloading your model there are no toolpaths, only the setup in the left hand plane. Another persons included a model this had toolpaths with this.
They were there, just turned off in the Browser.
John Hackney
Retired
