Hi all,
This post is to make any FFF users aware that there is an issue where the travel speed generated for FFF prints is very slow. This is causing prints to take up to 3 times longer than necessary.
This is occurring as the postprocessor is using this "High Feedrate" value in the 'Post properties'. Therefore we suggest a current workaround being to enter a suitable value in here.
Note, for a desired travel speed of say 100mm/s, we will need to enter 100mm/s *60 = 6000mm/min since printers require the speed to be in mm/minute.
The postprocessing team are aware about this and are working on a fix that should be implemented shortly, so bear with us!
Any further questions about this, please reply to this post!
Update
This issue has been fixed in all FFF postprocessors. To access the latest post please select the relevant post from the Fusion Post Library.
Note, users using older saved post versions will not have access to this fix.
