On machines with limited RPM I'd like the post to automatically adjust the feed rate by the proportionate amount that the spindle speed is limited by. This is adjusted from the current Haas NGC post.
I added this to the properties section at the head of the post so the user can enter the RPM on the post page.
MaxRPM: {
title : "Spindle Speed",
description : "Adjust cutting data based on machine rpm",
group : "Machine Lab",
type : "spatial",
value : 12000.,
scope : "post"
function getFeed(f) {
// var MaxRPM = 3000.0; // this line makes the logic work when uncommented
if (spindleSpeed > MaxRPM) {
var adjustmentRatio = MaxRPM / spindleSpeed;
f *= adjustmentRatio; // Adjust feed rate proportionally
if (getProperty("useG95")) {
return feedOutput.format(f / spindleSpeed); // use feed value
if (typeof activeMovements != "undefined" && activeMovements) {
var feedContext = activeMovements[movement];
if (feedContext != undefined) {
if (!feedFormat.areDifferent(feedContext.feed, f)) {
if (feedContext.id == currentFeedId) {
return ""; // nothing has changed
forceFeed();
currentFeedId = feedContext.id;
return settings.parametricFeeds.feedOutputVariable + (settings.parametricFeeds.firstFeedParameter + feedContext.id);
currentFeedId = undefined; // force parametric feed next time
return feedOutput.format(f); // use feed value
Solved by aju_augustine. Go to Solution.
Hi @rstpeng ,
To retrieve the values of MaxRPM, which is defined in your post properties, you can modify your post as illustrated below:
if (spindleSpeed > getProperty("MaxRPM")) {
var adjustmentRatio = getProperty("MaxRPM") / spindleSpeed;
I hope this solution proves helpful for your needs.
