I'm experiencing a error I've never seen before.
Every tool that I edit shows the one or both of these errors (see screenshots below) ...
I've had these tools defined in Fusion for over a year and have never seen these errors until yesterday.
Any idea why this is happening?
Solved by a.laasW8M6T. Go to Solution.
Hi
This Is a Bug that has been logged
I'm not sure when a Fix will be available though
Seems Maybe to be an issue with Inch tools, I haven't noticed the problem myself.
You can Re-enter the value and it should correct but that's quite annoying
Do we know if this bug is affecting toolpaths? I ran a 6061 part tonight, nothing too challenging. The toolpath looked good in the simulation. When I ran the part the 1/2" end mill snapped.
I wouldn't think so, Its possible that part lifted in the Vice, Seems to be a bit heavy of a cut, without seeing the File its hard to comment.
Its pretty hard to break 1/2" carbide endmill in ali
@a.laasW8M6T Ahhh yes! After stopping the machine I noticed that the part was slightly tilted in the vice, but the Mitee Bite Talons kept if from getting ripped out. I was thinking the crash and snap of the end mill caused that to happen. But it makes sense that it was the other way around.
Looking at the part now, I can see how the lift caused the cutter to dig deeper into the material and snap the end mill. Looking at my toolpath, I forgot to reduce my stepover. It was cutting a 3/4" depth at 6,000 RPM and I left the stepover at 50%. š¤¦š»ā
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Sure @seth.madore, here's a link to the file: https://a360.co/4aVkcv7.
It was too big to attach it to the post.
