Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
I'm getting "Diameter must be greater than ..." errors on every tool I edit.
6 REPLIES 6
simspacetn
375 Views, 6 Replies
I'm experiencing a error I've never seen before.
Every tool that I edit shows the one or both of these errors (see screenshots below) ...
  • "Diameter must be greater than the diameter of the tool shaft" or
  • "Diameter must be greater than the reference diameter"
I've had these tools defined in Fusion for over a year and have never seen these errors until yesterday.
Any idea why this is happening?
6 REPLIES 6
a.laasW8M6T
in reply to: simspacetn
Hi
This Is a Bug that has been logged
I'm not sure when a Fix will be available though
Seems Maybe to be an issue with Inch tools, I haven't noticed the problem myself.
You can Re-enter the value and it should correct but that's quite annoying
simspacetn
in reply to: a.laasW8M6T
Do we know if this bug is affecting toolpaths? I ran a 6061 part tonight, nothing too challenging. The toolpath looked good in the simulation. When I ran the part the 1/2" end mill snapped.
a.laasW8M6T
I wouldn't think so, Its possible that part lifted in the Vice, Seems to be a bit heavy of a cut, without seeing the File its hard to comment.
Its pretty hard to break 1/2" carbide endmill in ali
simspacetn
@a.laasW8M6T Ahhh yes! After stopping the machine I noticed that the part was slightly tilted in the vice, but the Mitee Bite Talons kept if from getting ripped out. I was thinking the crash and snap of the end mill caused that to happen. But it makes sense that it was the other way around.
Looking at the part now, I can see how the lift caused the cutter to dig deeper into the material and snap the end mill. Looking at my toolpath, I forgot to reduce my stepover. It was cutting a 3/4" depth at 6,000 RPM and I left the stepover at 50%. 🤦🏻‍
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
simspacetn
in reply to: seth.madore
Sure @seth.madore, here's a link to the file: https://a360.co/4aVkcv7.
It was too big to attach it to the post.
